Mission Planner for Android ?
It would be *very* sweet if Mission Planner could be compiled for Android, to run on a phone or pad, would be fantastic, and extremely useful for field-tuning.
We could connect using BT, UDP /TCP - and most newer devices do support USB host too (even if some require a miniusb-USB adapter)
Anyone knows how much work that would require, or whatever it's doable ?
(not sure about the lock-in it's based on (.net))
-  could we run it on Android using MONO ?
  • Unfortunately, it isn't easy to port APM planner onto Android platform, even with C/C++ via NDK.
    APM planner itself is a C# source code based on windows. The source portability is very bad for Android.
    So an rewrite is required. Unlike, OpenPilot's software design is good, and uses a lot of open source and also consider portability issues.
  • yes, I purchased it a while ago.
    The thing is it's still missing TCP/UDP , and it's missing some plane-related stuff
  • http://diydrones.com/profiles/blogs/coptergcs-android-ground ;)
    Is a WIP but all the good stuff is there.
