  • I am running MP on a win10 tablet, and when I select an alpha numeric field to edit, the keypad interface does not come up, so I cannot edit the field. It does work right in any other program on the tablet. Is there a tablet mode in MP that I haven't found yet?
    • I have kind of figured this out. I can select the space to edit, then manually bring up the keyboard, then edit the space blindly, hit enter, close the keyboard, then see if my edit was correct, or had any effect at all.
  • I still cannot get MP to quit hanging on start up.
    My notebook is an 11"  convertible and the main C: drive is SSD in the screen, and only if the hard drive in the detachable keyboard is connected will MP run.
    On W8 I had no problems with ejecting that drive.
    I have tried all the suggestions on this thread and none of them have worked. Including installing drivers from other sources as listed in this thread. Each time I have uninstalled the current drivers before installing new ones using the ignore signatures start up option.
    MP simply hangs on start up each time.
    The program works perfectly on my desktop after the upgrade to W10.
    • So I figured it out.
      MP does work on my tablet under W10
      The reason the program locked up on mine is because I had removed an SD card which was the location of the log files.
      MP expected it to be in a location which no longer existed.
      I would expect MP to tell me about that, but it did not. Instead it just locked up.
      I also came to realise that uninstalling MP did not remove all previous files, or references.
      I found the solution by reading the start up log files in MP's exe dir.
      Well all works well now : - )
  • Just a small point for those who don't know to avoid further posts, the option "run as administrator" only applies to executables, not .msi files. Only way to run as admin in that case is to enable the admin account and log in as that and reinstall.
    Incidentally one possible way round is to use the arduino dev kit as the old APM's are megas
  • Just disable driver signature enforcement.
    http://www.howtogeek.com/167723/how-to-disable-driver-signature-ver...
    The run the kit as Administrator.
  • One thing that has worked for me for some reason I cannot figure why is installing the drivers separately though this link
    http://pixhawk.org/static/px4driver.msi
    With this installer I got asked by windows with a separate pop up window I I want to install. it worked!
  • Just a note here to say I had the same (driver fail) install issue as Tony.
    I didn't "solve it" as such but found a work around. I installed the Arduino SDK which comes with drivers for the mega (which is what those particular APM boards are) and that worked fine.  Somewhere along the line the telemetry board started working too. Not sure if this was as a result of the Arduino software or not.
    re the suggestion of running from admin mode. Annoyingly the Mission Planner install is a .msi file so isn't right-click-able "run as" like .exe's are.  I tried running it from an elevated command prompt though... not sure that it made a difference. The drivers didn't install though like that either.
    So yeh... arduino software is a work around https://www.arduino.cc/en/main/software
    Arduino - Software
    Open-source electronic prototyping platform enabling users to create interactive electronic objects.
    • Thanks Johnny for the input. I will try that because I have had no luck even with a clean install of windows 10.
      • I upgraded my PC from Win 8 to Win 10 and has been trouble -free with Mission Planner for several months until 2 days ago, when I was trying to install the driver for PX4FLOW (Optical flow) for Pixhawk on my PC (without success), I got the following error message when connecting Pixhawk to Mission Planner via USB :--
            "Cannot establish a connection"
             " Index was outside the bounds of the array"
        This is the first time I see this error message. There is no problem with the driver as I can see "Pixhawk" in the connection tab. I tried uninstall and then re-install Mission Planner, but it did not help.
        Anybody has clue to what has gone wrong. ?
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
