Motor "nudging" (or not spinning properly)
Hi all,
Just got the battery for my first quad and connected everything and powered it up. I am having a problem where one motor nudges back and forth instead of spinning. See video at:
https://www.youtube.com/watch?v=0CrK5AoRdQI&feature=plcp
Is something fried? Or just a loose connection somewhere?
    This is usually a bad connection between the ESC and the battery, or the ESC and the motor. Disconnect, clean, and reconnect (firmly) all cabling to/from this motor, including the ESC to battery cable, the bullet connectors. Be mindful that you might have a problematic connection, which you do not want appearing as a result of vibration later, during flight.
  • I could add that all 4 motors were working correctly at first. Then I checked rotation direction and had to change 3 of them. After this the problem occurred.
