Heavylift variable pitch quadcopter
It is my first drone
Motor to motor distance : 140 cm
Rotor diameter:70 cm
Maximum size:210 cm
Weight: 1.6 kg ( esc, motors and wires) without batteries
Motors are 4 pcs http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9021
White gears are from HK450 class helicopter with one way bearing for autorotation
esc 4 pcs http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11430
Tested in the house tied to that piece couch. At full thrust it tried to lift the couch which has over 14 kg
I tried to use Arduino to level the drone but using just the accelerometer is quite hard. I'm trying now using accelerometer wii motion plus gyro combo
I filtered the data from the accelerometer using a simple low pass filter. I'm currently trying to understand Kalman filter.
I tested it outside but it failed to level the drone and have a little crash. The damage was only visible on the pipes. So I bought a new set
Is the accelerometer sufficient for the job?
I also bought a lot of sensors (sonar, barometric sensor with 9 cm resolution, gps, magnetometer 1 axis, gyro, and KKcopter controller board to replace my arduino)
  • can you get the ratings of the motors, and then plug all of your variables into the formula found here to get an idea of how much this quad can lift
    Helicopter Aerodynamics, calculating thrust loading, disk loading, power loading
  • 3690878975?profile=original
    3692241782?profile=original
  • Accelerometer is not enought to stabilize quadrotor. Main reason is that because of vibration.
    And also accelerometer can't stabilize yaw.
gotham liked gotham's profile
14 hours ago
DIY Robocars via Twitter
RT @RoboticMasters: Monaco GP Circuit in the Donkey Sim (coming soon). Including buildings, tunnel and all! https://github.com/robotics-masters/sim-donkeycar-f1/tree/f1-tracks @diyr…
yesterday
RT @breadcentric: Here are the details of #AWSDeepRacer finals: https://blog.deepracing.io/2020/12/01/aws-deepracer-league-finals-2020-round-1-schedule/ #awsreinvent2020 #AWSreInvent https://t.co/ovqsjp8V…
yesterday
RT @breadcentric: #AWSDeepRacer League #awsreinvent2020 Open race is on Dec 1st - Dec 31st in three categories, 15 DeepRacer Evo (with LIDA…
yesterday
RT @a1k0n: @SmallpixelCar @diyrobocars It's just something that's easy to track with chroma keying. I ended up using different colors on th…
Monday
Monday
RT @TinkerGen_: "The Tinkergen MARK ($199) is my new favorite starter robocar. It’s got everything — computer vision, deep learning, sensor…
Nov 23
Nov 23
RT @roboton_io: Join our FREE Sumo Competition 🤖🏆 👉 https://roboton.io/ranking/vsc2020 #sumo #robot #edtech #competition #games4ed https://t.co/WOx…
Nov 16
DIY Drones via Twitter
First impressions of Tinkergen MARK robocar https://ift.tt/36IeZHc
Nov 16
Our review of the @TinkerGen_ MARK robocar, which is the best on the market right now https://diyrobocars.com/2020/11/15/first-impressions-of-tinkergen-mark-robocar/ https://t.co/ENIlU5SfZ2
Nov 15
RT @Ingmar_Stapel: I have now explained the OpenBot project in great detail on my blog with 12 articles step by step. I hope you enjoy read…
Nov 15
RT @DAVGtech: This is a must attend. Click the link, follow link to read the story, sign up. #chaos2020 #digitalconnection #digitalworld ht…
Nov 15
RT @a1k0n: Got a new chassis for outdoor races (hobbyking Quantum Vandal) but I totally didn't expect that it might cause problems for my g…
Nov 11
First impressions of the Intel OpenBot https://ift.tt/36qkVV4
Nov 10
Nov 9
