  • Anyone else knowing how to make the servo move the full 90 degrees?
  • Make sure that on the gimbal page you have a full range like -90 to 90 or 0-180
    Then you may have similar range limits for the gimbal controller itself. Check that in the Gimbal Controller software.
    • The default values there were -45 and 45
      I tried with -90 and 90, but that didn't change anything. Will have to try with 0 and 180
      there is no gimbal controller, just a servo connected to pxhawk out 1
  • Hi there.
    You have to change, in the Mission Planner, the RCN_MAX value and the RCN_MIN value in the Full Parameter List from the CONFIG/TUNING sheet, where N is the OUT Port where your Servo is connected.
    Regards
    Esteban
    • Yes they are set to 989 and 2014 respectively. That is what the radio calibration min and max shows.
      Still only 90 degrees movement of the servo.
      huh
      edit:
      RC9_TRIM is set to 1500
      What does that mean?
  • Look back on the gimbal control page and you will see some adjustments for range.
    • I see just angle limits, which doesn't seem to affect anything.
      I tried with various values.
      I'm with the APM GS
