Need to use Pixhawk 2.1 Barometer for drone altitude
I am new to pixhawk. I am using pixhawk cube 2.1. I need to use pixhawk's own barometer to calculate the altitude. Please guide me that how to get readings of the barometer or the baro altitude. I am using PX4 firmware version 1.6.3. In the mavlink inspector (Qground controller), i have not seen any altitude thread. Do i need to use different firmware to get the pixhawk's built-in barometer working for the altitude or do i need to enable some parameter ?
Thanks!
  • Chimney? :) What kind of chimney..Now I am more confused.
    I don't know QGC. Why you simply don't use Mission Planner? It reads and provides barometer reading on its own. You don't need to do anything.
    Muneeb said:
    Yes i am trying to read barometer reading directly from pixhawk by mavlink inspector in QGC. is there any parameters to set to get the correct altitude with the barometer. Right now i am getting -77m Altitude (amsl). It almost seems to stay at this value. Our plan is to use the Pixhawk's barometer for the altitude estimation to fly the drone in the chimney. I don't have chimney access so i am testing the pixhawk's barometer in the indoor.
    iSkyMaster said:
    If I make a wild guess, you want to read the barometer reading directly off the PixHawk?
    You need to explain your question in details else people normally don't respond to vague questions.
    1. What is your setup?
    2. You need to provide more details.
    I am not very familiar with QGC, but in mission planner, it should read fine. Keep in mind there are many factors that can impact a barometer
    http://quadcopter-robotics.blogspot.com/2016/08/pixhawk-v248-bench-...;
    Check this link https://github.com/DroidPlanner/Tower/issues/1521
    Hi, I am new to pixhawk. I am using pixhawk cube 2.1. I need to use pixhawk's own barometer to calculate the altitude. Please guide me that how to ge…
  • Yes i am trying to read barometer reading directly from pixhawk by mavlink inspector in QGC. is there any parameters to set to get the correct altitude with the barometer. Right now i am getting -77m Altitude (amsl). It almost seems to stay at this value. Our plan is to use the Pixhawk's barometer for the altitude estimation to fly the drone in the chimney. I don't have chimney access so i am testing the pixhawk's barometer in the indoor.
  • https://diydrones.com/forum/topics/effects-of-frame-design-on-barom...
    Effects of frame design on barometer performance ( and all other non 3.3 specific AC questions)
    According to Randy the know issue of altitude loss after a high speed run is at its heart a frame issue. This seems to me a very worthwhile discussi…
  • If I make a wild guess, you want to read the barometer reading directly off the PixHawk?
  • Do i need to set some parameter to read the barometer altitude? I am getting Pressure_alt around -79 in QGC mavlink inspector. I don't understand what is this. Please let me know what is required to read the correct reading of the barometer from pixhawk.
    iSkyMaster said:
    If you are using telemetry on Pixhawk or transmitting telemetry via video, it will tell you the altitude using ground control software like Mission planner or others.
  • If you are using telemetry on Pixhawk or transmitting telemetry via video, it will tell you the altitude using ground control software like Mission planner or others.
Abdulatif Tlaib liked Ryan's profile
8 hours ago
DIY Robocars via Twitter
RT @SmallpixelCar: First time at @wsraceways. After tuning @HokuyoUsa lidar signal and camera sensor on @NVIDIAEmbedded, my car was able to…
Sunday
RT @breadcentric: The handy bit about racing with self-driving cars is that one can type while the car is racing. Report from #AWSDeepRacer…
Jun 18
RT @chr1sa: Our Bay Area @DIYRobocars meetup is now at 2,700 members. Next in-person events (in Oakland) are training day on July 17 and…
Jun 18
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Jun 10
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
