No data displayed, just 0's
Hi!
I can't get the OSD to show any values. They are all zeroes. Iv'e done a lot of googling but havent found the key yet.
MinimOSD v 1.1 with firmware 2.0. Updated charset. Bought a cable on Ebay to use telemetry at the same time.
APM 2.6 with Arducopter 3.1.
I switch it on, it says "Waiting for mavlink". I connect the telemetry. The previous text will go away and everything seems fine, all the text is there, but it is all zero/null values. The Heartbeat icon is flashing.
I read about the Arducopter not sending values by default, that you have to set the SR3-parameters. But like someone said, that are not there!
Also, going in to MissionPlanner / setup / Optional Hardware / OSD and clicking there, does nothing.
I tried using another MinimOSD that i took off of my Octocopter, that one shows the exakt same. But on the octo, it works with another APM 2.5.
I get the feeling that the APM is not sending out the data that the Minim needs to hear?
Please help, my hair is getting grey over this one...
  • Rolf,
    thanks, you were right, it was the cable! Your suggestion to hook up only the radio got me thinking.
    I exchanged TX and RX pins on the APM end with each other, and then also exchanged them on the Radio end.
    After that, 100% difference. Both APM and telemetry works now.
    Mind you, this was a cable i bought from Ebay, not one I built myself since I didn't want to fiddle with it. :)
    Thanks!
    /Magnus
  • check the TX connection from minimOSD, if this connection is missing you will only get the heartbeat message.
    minimOSD sends request for the data that shall be returned by APM.
    • Hi Rolf,
      thanks for the reply: My splitter cable indeed has only the RX connection to the MinimOSD. The Telemetry-unit has both RX and TX.
      Are you quite sure that both MinimOSD and Telmetry should have both RX and TX when used in parallell?
      As mentioned here: http://copter.ardupilot.com/wiki/common-minim-osd-using-with-a-grou...
      This is the cable I'm using: http://www.ebay.com/itm/251416147164?ssPageName=STRK:MEWNX:IT&_...
      Thanks again!
      /M, Sweden
      • Ok, if you have a radio telemetry connected then this should do the request to the APM (no TX from minimOSD) but  first after connecting to Missionplanner or some other groundstation software.
        • That's how I read it too. The connection to Mission Planner works well.
          • is both LED's on the minimOSD on?
            • Yes. It reads the heartbeat when I connect to Mission Planner. It just doesn't read any values from it.
              The display is fine, nice and sharp letters and the heartbeat symbol is blinking.
              • do you get the telemetry data in Missionplanner?
                • Seems I can't reply to the latest response, so I'm responding in the wrong order here..
                  I suspected the cable as well, and moved the RX wire to the TX position, but then I did not get any mavlink connection at all. When it is in the original position, as mentioned, I get a mavlink connection. Just no data.
                  • if you are using the 3DRobotics radio telemetry try connecting just the minimOSD directly using the cable used for the radio telemetry on the APM.
