Thought the problem was a potentially faulty APM 2.6 so unwrapped my PixHawk. Same problem.
In MP, it connects and downloads the firmware. Pixhawk then gives the successful happy song. Select connect via Mavlink:
- starts 30 second countdown
- red connect changes to green disconnect
- timer goes to 0
- continues trying or doing something for another 1 1/2 minutes while countdown stays at 0
- then get No Heatbeat error.
In Windows 8, Device Manager, Com 5 is set to 115200, 8 bits, no parity, 1 stop bit, no flow control, FIFO buffers.
In MP, Com 5 PX4 FMU v1.6 (COM5) is selected.
Tried:
- restarting the computer
- connecting via a different computer (windows 7 and an older version of MP)
- four different USB cables plugging into different USB connections (getting desperate)
- different com settings
I'm beginning to think i'm in a no heatbeat black hole. will see if i can setup the radio (but can i do that without mp?)
ok
i found this solution
nothing wrong with gps or any other ..
i connect lipo to the FC wait couple seconds then connect the usb cable 115200 and putting the right port connects to mission planner right away......then ready to setup
i have done all above and i get the following on win 10
fail to create log...wont log this session and then i get the usual no heartbeats......
the funny thing is that i have done this before i had few difficulties connecting but something happened and connected...i thing i played with the b rate 38400 to 57600..........any ideas
Hello all,
I have the same issue. I have a pixhawk board, I could upload AC3.2 firmware but then I can't connect the board to the mission planner. I tried different things: connect/disconnect GPS/compass modul, tried on different USB port, even tried with separate power module but in the end all ended with no heartbeat packets received error message. I don't know what to do further. Please help if anyone can tell me what to do.
sometimes it's magic. usually once you figure it out it keeps working.
i'd call/e-mail 3DR customer service if you feel like you've tried it all. they are responsive.
Thank you, I'll follow your advice.
I haven't got support from 3DR, but after reading other posts on the forum, I decided to replace the SD card. After replacing SD card, all things went well.
well done.
i wonder if 3DR checks for a heat beat before they ship them out or if they only do a direct connect?
Well, just to add to the mystery, our first attempt at disconnecting the GPS from Pixhawk and trying the Mavlink failed. My friend had disconnected from the GPS end and left the cable attached to the Pixhawk.
After removing the cable completely from the Pixhawk and also removing the i/o cable from the GPS, we were able to restore the Mavlink. Seemed it needed everything removed from the GPS connection on the Pixhawk. As to why, I'm clueless?!
If (big if) removing the cable completely had anything to do with it besides coincidence, then the reason is most likely a loose connection on the board that gets tweaked when messing with the connection terminal or a cable with an intermittent short.
That was my initial thought too and why I asked my friend to remove the cable from the Pixhawk, although there were no signs of issue wit the cable. In my head I was thinking something had shorted/tricked the mavlink into bootloader mode.
Whatever it was, I was just very pleased to be able to get the issue resolved without needing replacement parts and to get my friend flying his new toy.. and this thread was my only source of info for doing that.
1
2
3
of 3 Next
