T3
No power from RC Pins
hi to all,
After several succesfull flights with my Arduplane (v2.26) i have problem.
when i plug my 3s lipo to esc, only a red led(PWR) lights up on ATMEGA 2560 board. When i plug the usb everything works great (except servo movement) and i can play with mission planner and read inputs from all sensors and rc inputs.
i may exceded the current trying to use 7 12gr digital servos (4 for flight control-3 for camera). wrong servo throws fried one of my servos and since then the problem appeard (iam not exacly sure if it happend before or after the new firmware update) .
i already checked for the soldered part and its ok.
is there eny way to reset a fuse or something? should i buy another fuse or buy another board? power the board using another trick??
thanks you all
James
  • Have you had any issue with the PPM encoder after this fix?
  • T3
    Hello everybody!!
    Problem found and Solved!!!
    it seems that servo burnout, burn this little ground line on apm board from rc pins ground to board ground
    3692308361?profile=original
    i solderd a piece of cable from rc pins ground to board -+ holes and everything works again!! be carefull when using many powerfull digital servos with high draw.
    3692308176?profile=original
    https://storage.ning.com/topology/rest/1.0/file/get/3692308361?profile=original
  • T3
    Thanks a lot Burt, i was hoping this to work out too.
    It seems i have exacly  the same symptoms like Dave Whittington http://diydrones.com/profiles/blogs/ardupilot-mega-home-page?id=705...  discribes a year ago, but my jumpers are solderd..
    a minute ago i powered apm board from + - holes with a seperate UBEC and aditionally a pluged my esc on rc rail, everything lights up but servos still dont move in any mode..
    i cant locate the fuses on APMboard, how the look like/ name? for sure nothing missing i double checked all images with my board
    i will have my polymeter back tomorow to check every end..
    Thanks again for helping me Burt
    James
    I have had a very similar problem. The last time was after 2 good flights. After changing batteries, I couldn't get the yellow gyro, or red GPS led to light. I had no xbee connection. After hooking the plane up to usb I could upload firmware, but couldn't connect to change settings. I could connect to test all the hardware with the MP terminal, all tested well.
    I also when over all solder joints on the APM, tried it again same thing.
    I then loaded the Hil firmware, now everything seemed to work. I then reloaded the 2.26 again, had the same problem back again. ???
    I next loaded 2.24 firmware from the Arduino interface, It rebooted the APM and all seemed to work again.
    I have had this happen 2 times both times I had to go to older firmware, then reload the 2.26.
    Give this a try and see if it works for you.
    Burt
    Hi James,
    I'm sure you have, but I will just ask! Did you check this page here
    And have you looked at this information here
    You can power the board in another way by following the above steps , I thought that the fuse reset itself after a power down on the APM, I could be wrong!
    Let us know how you come along with the above information.
    Regards
    Martin
DIY Robocars via Twitter
Jul 4
Jul 4
Jun 25
Jun 25
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
May 11
