Old diydrones.com GPS module and problems with it
Hello. Today I've got a GPS module GTPA010 on MediaTek_V12 which was bough from diydrones.com some time ago.
Now I have some troubles. It has 6-pin h jst connector, but when i look at the bottom i can see 5outputs: GND, 5V, OUT, IN, EN. How can I know which wire from connector (which pin) suite each output. I don't know if the top red wire is GND or it is nothing, but the second black wire is GND. Can you help me?
Can I somehow check it with multimeter? How?
3691326635?profile=original
  • Does your multimeter have a continuity mode (makes a tone when you have a complete circuit like touching the probes together)?  If yes you can put one probe on a pin on the  connector or a wire and then touch each pad until you get a tone that indicates the wire goes to that pad.  If it doesn't have a continuity mode use resistance mode and look at low resistance to indicate a wire is connected to a pad. Having a tone is much easier, though so you don't have to keep looking at the meter.
    Piotr said:
    Fuck, and now I'm not sure, cuz Michelle said smth different. I will try to check with multimeter, but don't know how to do it. I will figure out :P
    Ray Anderson said:
    No, I was stupid and pasted the wrong link apparently.
    https://www.google.com/url?sa=i&rct=j&q=&esrc=s&sou...
  • Ignore me, I don't have this same issue.
  • Fuck, and now I'm not sure, cuz Michelle said smth different. I will try to check with multimeter, but don't know how to do it. I will figure out :P
  • No, I was stupid and pasted the wrong link apparently.
  • No worries, though I would test yourself to be sure. I am using mine with an arduino also but not using the cable - i soldered pins directly to the pads:  http://imgur.com/a/FOrji
    Yes gps out goes to arduino in (Rx)
    Piotr said:
    Thanks a lot, you are my hero !
    To be sure, I need to connect Out to Rx in arduino?
  • Thanks a lot, you are my hero !
    Michelle C said:
    I have that module but mine is v13.  Testing with a multimeter gives :
    red -> gnd
    black-> 5v
    yellow -> in
    green -> out
    blue -> gnd
    white -> no connect
  • I have that module but mine is v13.  Testing with a multimeter gives :
    red -> gnd
    black-> 5v
    yellow -> in
    green -> out
    blue -> gnd
    white -> no connect
  • Maybe I'm stupid but can't find anything about the module connection in this link.
    Ray Anderson said:
DIY Robocars via Twitter
Jul 4
Jul 4
Jun 25
Jun 25
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
May 11
