One of the motors does not spin correctly.
After swapping ESCs with an other arm it seems that it is motor related. The 'problem' stayed with the motor when two ESCs were swapped around. One again I also moved the signal connectors back and forth. All situations resulted in the same motor demonstrating this 'twitching' behavior.
This is a terribly boring problem... I want to get onto the 'good stuff'. ;-)
Any more ideas?
Wes
  • One of the wires going into the motor had a poor solder joint from the factory.
    This was found by stripping off the heat shrink and inspecting the joint.
    Repaired and the motor is working fine now.
  • Odds are its a bad bullet connector. Try swaping a couple of the motors around and see what happens.
    DO NOT PUSH THE STICK UP TO HIGH WHEN THE MOTOR STUTTERS OR YOU WILL BLOW THE ESC!
    Neil
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
