  • I know that this question is a little bit out of the thread but do anyone know if there is a possibility to combine gps, sonar and optical flow in apm mini 3.1. Nice work by the way!
    Awesome!
    Do we have transfer from GPS to flow and back yet? :P
  • Thanks to Goro, Pual, Randy.
    I got Optical Flow works well. Here is the video clip fling with OF
    P.S : The GPS is for only mag sensor not GPS
  • Hi Paul,
    FW : AC3.3.3 RC2
    Pixhawk
    I'm still struggling with OF.
    I found that Lidar is indicating correct alt  and OF log is shown in MP's log analyzer ( but not match each other OF.flow, OF.body IMU.Gyro like wiki )
    Even with AC3.3.3 RC2 + EKF_GPS_TYPE=3, my copter can't be armed with the message GPS 3D Lock error.
    I followed your instruction about NSH and it shows no error
    3702173023?profile=original
    It'll be very appreciated if you correct me ^^;
    P.S : Log file is attached here ( https://drive.google.com/file/d/0B713ZYObFHOTM0dncmFFdzJaOVE/view?u... )
    3702172974?profile=original
    3702172587?profile=original
    2016-01-30 18-16-21 3.bin.log
    • Hi Kyomo,
      Your log shows GPS_HDOP_GOOD parameter is not set correctly. You need to set it to 9999.
      Alternately, you can disable the pre-arm GPS check by setting ARMING_CHECK to -9.
      • Thanks Goro,
        I found it had not only one problem ^^;
        1st, I've set parameters to what you mentioned but still not armed.
        2nd, my OF has power issue so I had to power it up via USB first.
        ( I have two OF but both have same issue -.- )
        3rd, the worst one...my I2C splitter had faulty even though OF looked normal blinking LED signal.
        By replacing it with other splitter, it worked.
        With the above 3 treatment it was armed in Loiter mode without GPS.
        Thanks again Goro and Paul you guys' sharing information.
        • Hi!
          Did you manage to arm without GPS-module on the board? For example, can you totally disconnect the GPS-module and arm the copter with px4flow+lidar or you still need the 3dfix in the home position?
          • Yes, what I did
            GPS=disconnected
            GPS.Mag=connected
            FlightMode=Loiter
            and it was perfectly armed.
            • Thanks a lot!
              You say that you are using AC3.3.3 RC2. Have you compiled it from the sources or just downloaded through the Mission Planner (as beta version firmware)?
DIY Robocars via Twitter
Sep 9
RT @chr1sa: We've got another virtual @DIYRobocars race tomorrow at 9:00am PT. Two dozen autonomous cars will compete, four at a time. Ther…
Sep 4
Sep 1
Aug 31
Aug 31
RT @ExplorerRobocar: Sometimes, I am really a big kid!! Having fun with my virtual RC car on the @diyrobocars track 😜😉, by using the « AR R…
Aug 24
RT @grepLeigh: @donkey_car @unity3d @TensorFlow ~1050 episodes into training, my agent learned to erratically drive in the left lane. 🤖😆 ht…
Aug 24
RT @EclipseCyclone: Sweet! http://Robotec.ai high performance #ROS 2 @unity3d #CycloneDDS bridge for @AutowareFdn @SVLSimulator now…
Aug 24
RT @a1k0n: My car had a lot of trouble getting around the track at the last @diyrobocars event -- only one actual finished lap during the r…
Aug 24
RT @SmallpixelCar: This is the run time map https://t.co/VzykOkUt2G
Aug 24
RT @SmallpixelCar: Made a lot progress on Warm Spring Raceways track. Almost finished one lap. https://t.co/nUVpufZQyP
Aug 24
RT @AntonioRobotics: Super fun time seeing these autonomous cars race at @circuitlaunch for the @diyrobocars quarterly meet up! The demolit…
Aug 15
RT @a1k0n: I thought my dumb localization code was still working at the new @circuitlaunch track, but it was just *barely* working. I shoul…
Aug 14
RT @DAVGtech: Recording of entire in person @diyrobocars race today @circuitlaunch. Fast forward a couple hours to go straight to the racin…
Aug 14
RT @SmallpixelCar: This is the run time map. Very noisy Lidar signal https://t.co/bAbeVUMi10
Aug 14
RT @SmallpixelCar: Today’s race with @a1k0n at @diyrobocars We both decided jumping over the wall was the way to break the 11s lap time. Th…
Aug 14
