This is a OSD for FrSky Smart Port telemetry based on minimosd-extra.
To get this working you need:
- MinimOSD or MavlinkOSD
- UART to Smart Port Inverter https://github.com/razvanstanga/minimosd-frsky/blob/master/S.PORT_inveter.png
- FTDI 5v connector http://www.robofun.ro/conector-ftdi-5v
Installation:
- mkdir ArduCAM_OSD
- cd ArduCAM_OSD
- git clone git://git.razvi.ro/minimosd-extra-frsky.git .
- copy the the content of libraries in c:\Users\YourUser\Documents\Arduino\libraries\
- open ArduCAM_OSD.ino in Arduino
- select from Tools > Board > Arduino Pro or Pro Mini (5v, 16 MHz) w/ATmega328
- upload
Working:
- battery voltage from current sensor (FCS-40A)
- cell voltage (in temperature slot) from lipo voltage sensor (FLVSS)
- amperage from current sensor, old hub vfas (FAS-40/FAS-100/FAS-100-XT) and new smart port (FCS-40A)
- altitude form bario sensor (FVAS-02H)
- gps (GPS V2)
- low battery warning
- you can use Config. Tool to edit the settings
I used the following sources to write it:
https://code.google.com/p/minimosd-extra
https://github.com/zendes/SPort_OSD
https://code.google.com/p/telemetry-convert/wiki/FrSkySPortProtocol
https://code.google.com/p/opentx/source/browse/trunk/src/telemetry/frsky_sport.cpp
Any help on this is welcomed.
I have not tried frsky sp2uart. I suggest you make it. It's very cheap.
Cheap maybe, but not necessarily easy.
How do you download your files and libraries to be put on the minimosd? I cant find any .Zips or download links in the URL you posted.
The source you linked to uses a S.bus signal inverter. is that essentially the same thing you made? Or would you still recommend just making it my self? I can solder, but not so great at understanding electrical diagrams.
You can find instructions here
http://git.razvi.ro/?p=minimosd-extra-frsky.git&a=blob&h=a5...
S.bus signal inverter should work also.
This is how it looks on my setup.
