Parallax Propellar Auto Pilot
Here is my code for the Parallax Propeller CPU using the guts of a Wii nun chuck as the accelerometer.The code is modified from Paul Huber's to use the nun chuck data.For a $15 accelerometer it works nice. Still worling on project.
AutoPilotTV.spin
  • Earl: I looked at the pcb layout, you must have some 0.1uF caps to decouple the 5V supply, located
    right at the chip power and ground pins. Also a 10uF cap at least on the 5V. A ground plane helps a lot, too.
    CPU's will not work without these caps. Not reliably, at least.
  • Here is the latest code with all the sensors working..
    Also what I will fly...
    And the first circuit board..
    Earl
    Art-Hrz-OVL-41-fp.spin
    https://storage.ning.com/topology/rest/1.0/file/get/3691938916?profile=original
  • T3
    The accelerometer alone is useless for aircraft tilt sensing in coordinated turn. Search more on the forum.
  • This is my code for the barometer i2c module sdk500. It is written in spin code for the parallax propeller.
    Earl
    Testi2CbaroTempPRESS_MODULE - Archive [Date 2009.04.03 Time 00.30...
    https://storage.ning.com/topology/rest/1.0/file/get/3691926176?profile=original
  • Here is new code with a 'ping' ultrasonic altitude. I now need to integrate the compass and altitude module.
    AutoPilotTV2 - Archive [Date 2009.03.30 Time 19.34].zip
    https://storage.ning.com/topology/rest/1.0/file/get/3691925624?profile=original
