There is a camera calculator that gives you the distance between the lines of the waypoints so you the wanted overlap of the photos.
That is good function, then use the grid function to make a pattern.....personaly i would like to see the option for Zamboni style turns at the waypoints instead of the present function.
i´m currently doing my mapping with zamboni turns and the accuracy is way better..but then it is manual work with the wp
Search the forum and you will find some people using zmboni
