250 Quad with Pixfalcon help
I converted my ZMR250 from a Naze 32 to a Pixfalcon. I got everything setup and vibrations looks fine.
I then did a auto-tune on the Roll axis and would like to know if it is normal for a small quad or should I be concerned with the low values.
Stabilize Roll = 4,873756
Roll P = 0,03859347
Roll I = 0,03859347
Roll D = 0,001254361
Imax = 0,444
Filt = 20,000
Firmware Ver. 3.4.6
I did try to auto-tune the Pitch axes as well. But the quad just fell out of the air close to the end of the cycle because of a dodgy battery.
I got new batteries and would like to attempt autotune again. I just need some reassurance.
Henry
  • Hi , I posted it in the Copter 3.5
    Copter 3.5
    Discussions and support for Copter 3.5
  • Hi Henry,
    thanks to yours post here, I see the exact same problem I have!
    I suggest you to join the ardupilot community on the new forum at https://discuss.ardupilot.org/
    Please remake this post there and I'll join it with my same experience, I need to fix it too asap :) ...with no wind the little quad its perfectly stable, but as soon as a little breeze comes in its going drunk and not stable anymore :(
    Lets work on it Arducopter for little quad!
    ArduPilot Discourse
    ArduPilot Discussion Server
  • Hi I upgraded to Ver 3.5
    Here is a flight log if someone can look at it and point out problem areas please.
    Did not use autotune. I used PID's that flew OK and based on other users settings. I flies ok but seems that the slightest wind make it twitch. In no wind it is very stable
    2017-07-30 09-15-25.bin
    2016-11-27 11-06-06.tlog
  • No 250 pilots out there????!!!!!!!
    I am a bit worried because it can not be set that low under Extended Configuration. You can do it under the full parameter settings but you get a warning that it is out of range.
DIY Robocars via Twitter
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
yesterday
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
RT @a1k0n: This was epic. My car was barely working this morning, had to make a lot of changes and extremely dirty hacks. Post-race analysi…
May 22
DIY Robocars @ Circuit Launch, 3/7/2020 https://twitch.tv/diyrobocars
May 22
