Hi all, I am new to the forum and about 2 months into a rather large x8 copter. I flew a flamewheel quad to get myself familiar with the mission planner and general drone flying, as i am a fixed wing pilot of 20+ years. Has anyone run a large jeti spin pro (mine is a 300 mated to a T-Motor U-15) esc through a pixhawk 2? I can arm the flight controller but cant get any reaction from motors. No initial beeping or anything. I did calibrate the esc's individually with the recomended radio style calibration, and it all worked fine. Once plugged into the PH2, nothing. Only running 4 motors just to test spin motors for now. Planning to start a small scale version to configure x8 in PH, but I would like to figure out this issue quickly, trying to fly the big guy in a couple of weeks when the fuse is completed. Wondering if i need the jeti box to configure esc's properly to work with PH2, or some other setup is wrong. I do have a pretty long run of wire from the PH2 to the esc (4' to front 6' to rear), wondering if i need (or can) step up signal voltage to esc due to voltage drop. I am running 14awg servo leads to try to combat this. Any help would be appreciated as i am a wrench user instead of a keyboard user (no programming experience). Thanks in advance.
  • Thanks for the input fellas. We are still in development of the craft, I will post some pics and video when appropriate with our timeline. However we did finally get props on her and spooled the motors today. Empty she wants to lift with almost no throttle input... its suprisingly quiet, T-Motor did a good job on motors and props.
  • Wow, that will be a monster machine. Are you talking about a 200 lb. payload or gross vehicle weight? If you are talking 200 lb. payload it will be under powered. I figure your motors ,esc's, and 12 s battery for each motor will weigh ~ 100 lbs. 300 lbs. puts you at ~ 70% power and we haven't even included the frame weight. Any thing above 70% hover power is dangerous because there is not enough reserve for maneuvering and accelerating. If the total gross weight is 200 lbs. it will hover at 55% power and will have enough reserve to still fly if you loose a motor.
  • Sounds like quite a monster. I would love to see pictures if you are able to share.
    -Brian
  • Thanks Brian,
    I will be powering the autopilot with 2 separate battery packs, and now that I know about the servo rail, a separate pack for that. I cant go into the details of the x8 we are building yet, but soon I may be able to. I will just say that it will carry around 200lbs. Should be putting power to the props within a week, should be interesting!
    Thanks,
    Jon
  • Jon-
    If the pixhawk 2.1 is the same as the original pixhawk, then all you should need is a single BEC plugged into any spot on the servo rail in order to power the opto-isolators on the ESCs. If I remember correctly, the main difference between the 1 and 2.1 is that on the pixhawk 1 powering the servo rail will also act as a backup power supply to the autopilot, while on the 2.1 the servo rail is not connected to the auto pilot's power supply. If that is the case, then I would look at using 2 mauch modules to power the auto pilot, and another high quality BEC to power the servo rail and ESC opto isolators.
    Out of curiosity, what payload are you flying that uses a 40" prop? I have an X8 with 30" props that we use for aerial spraying, and it is quite a beast, I can only imagine what a 40" prop must be like!
    -Brian
  • Thanks for the reply OG, but we figured it out last night. Rereading setup, and some other blogs, the servo rail isnt powered... the jeti esc's need to see 5 volts to run. Everything is running like it should now, and boy what a noise these big motors make! Now my question is, what is the best (most reliable) way to power the rail? We just pugged a BEC'd lead into the rail. I will need a all 8 outputs monday when I run all 8 motors...
  • Have you disabled pre-armed checks ? also what firmwear is your ESC running yes you will need to configure your ESC properly?
  • More info...
     -running two 16000mah 6s packs in series for test flying on each esc/motor combo. so 12s
     -40" T-Motor props
     -spektrum dx6 gen2 radio for now, dx8 gen2 in the works
     -using a satelite rx for now, will end up with telemetry system, and fly without a rc transmitter at some point
     -separate power supply for PH2
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
