  • Are you referring to a specific Microhard radio?
    We are looking into digital and analogue radio's for use of Command and control link but also for camera feed and gimbal control all over one radiolink.
    Jason Franciosa said:
    Yes it works, I have done it, but it's not reliable and range is horrible. I recommend against it.
    pixhawk and microhard
    Does anyone know if it is possible to use a micro hard nano ddl's serial pass through port for the pixhawks telemetry? Thanks, Cody
  • can you show me steps of configuring and setting up of the module?
  • Yes it works, I have done it, but it's not reliable and range is horrible. I recommend against it.
  • Hi
    look, the telemetry board works solely and transmits and receives data. but there are two problems. 1 its loop back doesnt work
    2 the mission planner can not receive heart beat
    I dont know what to do and how to go forward
    John said:
    HI mohsein,
    Can you describe more the issue, we might be able to help solving your problem.
  • HI mohsein,
  • unfortunately I have not get successful in solving the problem
    but my guess is that there should be some problem in the USB to serial devices which have been used in this middle
    hope to solve it soon
    pray for us
  • Hi Mohsein,
    have you solved the problem? i have the same problem with microhard P900 .
    mohsein said:
    Hello
    thank you for making such subject
    I have recently connected a nano series to the pixhawk but it can not connect to the mission planner. the link has no problem and it can get and send data correctly. i have set the baud rate to the 57600 (both pixhawk and telemetery 1) but I can not connect to mission planner
    I want to know if there is any point I have to concern in order to solve this problem
    thank you so much
  • Yes, it should work.
    I've done it with Digi Xtend. It is a similar digital modem.
    • Hello
      thank you so much
DIY Robocars via Twitter
Sep 9
RT @chr1sa: We've got another virtual @DIYRobocars race tomorrow at 9:00am PT. Two dozen autonomous cars will compete, four at a time. Ther…
Sep 4
Sep 1
Aug 31
Aug 31
sam liked Jimmy Oliver's profile
Aug 25
RT @ExplorerRobocar: Sometimes, I am really a big kid!! Having fun with my virtual RC car on the @diyrobocars track 😜😉, by using the « AR R…
Aug 24
RT @grepLeigh: @donkey_car @unity3d @TensorFlow ~1050 episodes into training, my agent learned to erratically drive in the left lane. 🤖😆 ht…
Aug 24
RT @EclipseCyclone: Sweet! http://Robotec.ai high performance #ROS 2 @unity3d #CycloneDDS bridge for @AutowareFdn @SVLSimulator now…
Aug 24
RT @a1k0n: My car had a lot of trouble getting around the track at the last @diyrobocars event -- only one actual finished lap during the r…
Aug 24
RT @SmallpixelCar: This is the run time map https://t.co/VzykOkUt2G
Aug 24
RT @SmallpixelCar: Made a lot progress on Warm Spring Raceways track. Almost finished one lap. https://t.co/nUVpufZQyP
Aug 24
RT @AntonioRobotics: Super fun time seeing these autonomous cars race at @circuitlaunch for the @diyrobocars quarterly meet up! The demolit…
Aug 15
RT @a1k0n: I thought my dumb localization code was still working at the new @circuitlaunch track, but it was just *barely* working. I shoul…
Aug 14
RT @DAVGtech: Recording of entire in person @diyrobocars race today @circuitlaunch. Fast forward a couple hours to go straight to the racin…
Aug 14
RT @SmallpixelCar: This is the run time map. Very noisy Lidar signal https://t.co/bAbeVUMi10
Aug 14
