Pixhawk Bicopter
Hi all,
Im facing issue in bicopter flying through pixhawk.
whenever I try to take off from the ground the bicopter spins (yaw) in both the directions.
I calibrate all the required things and done the integration according to ardupilot web page:
M1 - Throttle right (Motor) - Clock wise prop
M2 - Throttle left (Motor) - Counter clockwise prop
M3 - Servo right (Servo)
M4 - Servo left (Servo)
Please find the log and parameter attached in this post kindly help on this issue.bICOPTER.zip
  • It sounds like you may be experiencing a problem with the motor and servo configuration. Double check that the motors and servos are connected to the correct channels on the pixhawk and that they are spinning in the correct direction. https://cookieclicker-2.com/
    Cookie Clicker 2
    Cookie Clicker 2 is an idle game in which players can have endless fun collecting cookies. Click on a giant cookie to get as many cookies as possible.
