hello there
i have question about ESC calibration on Pixhawk flight controller, when i calibrate esc from receiver it's calibrated and when i have unflaged battery and then plugged it's have off beeping it's means calibration successfully, but when i have reconnected ESC control cables to Pixhawk ESC steel beeping i have calibration ESC from Pixhawk too but have no change it's steel (beep...beep...beep)
need help to solution this problem.
it's my quadcopter details:
T-Motor air gear 350
ESC AIR 20A with no bec (ESC have only 2 wire, and it's connected to Pixhawk ESC in port like 1 2 3 4 )
battery Multistar High Capacity 4S 5200mAh Multi-Rotor Lipo Battery.
most ESC's beep on PWM loss, some, are extra nagging, and beep of no PWM.
Pixhawk does not output PWM until you hardware-arm it.
Thank Andre for your answer you think it's normal? but i have seen many videos about Pixhawk Calibration and every Calibration process completion ending ESC beeps after battery was unplugged end plugged in. for example it's one of this https://www.youtube.com/watch?v=Hl-Q7RPOn18
best regards.
not sure if we are speaking about the same thing so: this is "normal"
-When Pixhawk is NOT in calibration mode:
-connect power
-no beeping from motors after an initial sound ESC's make.
-arm, (ESC gets PWM)
-then disarm
- now there is a "beep" every 2-4 seconds from ESC's that lost PWM.
- any behaviour can be programmed, also "no-beeping-ever" - for those who program SimonK or otehr open firmware to ESCs.
my ESC beeping after i have connected battery it's voice like beep...beep...beep
but i tested when i press Pixhawk safety switch button it have one beep and stop beeping end it's armed quadcopter.
but when i calibrate esc from receiver it's calibrated and when i have unflaged battery and then plugged it's have off beeping it's means calibration successfully
i have question how to tell Pixhawk flight controller that ESC is calibrated?
