Pixhawk Failed CMD: 241
I am trying to setup my pixhawk through the APM 2.0.20 GCS on a Macbook Pro. I cannot get passed the accelerometer calibration as it only displays "Time Remaining Until Timeout: " and it does not ask me to flip the pixhawk in any axis, nor does it tell me to hit any button. It only displays the time remaining until about 10 seconds and then says Failed CMD: 241. It gives no explanation, and I have not found much about that particular failure on the internet.
Please help!!!!!!!!!
  • I got this when I was trying to calibrate a board with APM:Copter 3.3.3. Finally found some threads about it although the solution wasn't explicitly mentioned (https://github.com/ArduPilot/apm_planner/issues/945). For me checking the "Enable Ardupilot Text Severity Compatibility Mode" resolved the issue and I was able to calibrate successfully.
    Can't calibrate accelerometer · Issue #945 · ArduPilot/apm_planner
    When I try to run the calibration, I get the below screen: Here's the debug file: DEBUG 2016-05-17T22:38:04.083 UAS::executeCommand 241 conf 0 pa…
  • In the end I calibrated mine with the Windows version in a VirtualBox emulation.
  • Same here with APM Planner and Macbook Pro. Pixhawk 3DR
  • I'm getting the same response on a mac pro using apm too, for my 3dr diy hexacopter.
DIY Robocars via Twitter
RT @a1k0n: Starting on a rough guess of the track centerline as an SVG. Then I use svgpathtools to generate equally-spaced points w/ direct…
9 hours ago
RT @a1k0n: This rules. My existing code isn't going to work *at all* -- the track planner and precomputed map are out. However, it forces m…
9 hours ago
RT @chr1sa: Our new @DIYRobocars track at @circuitlaunch is fiendishly hard & crashtastic fun. Combines hairpin curves with an intersection…
11 hours ago
The May @donkey_car newsletter is out, with news about release 4.2, next events and more https://donkeycar.substack.com/p/may-newsletter
yesterday
yesterday
yesterday
RT @breadcentric: Bingo card for AWS DeepRacer Finale, starting in 10 minutes on https://www.twitch.tv/aws ! #AWSDeepRacer #DeepRacer #Machin…
yesterday
RT @NVIDIAEmbedded: It's #NanoFriday - the RB-0 uses the same suspension concept as #NASA's newer differential-bar rovers. This educational…
yesterday
RT @chr1sa: On May 22, we're returning to in-person AI @DIYRobocar racing at @circuitlaunch. The Amazon @awscloud DeepRacer team will be pr…
Wednesday
RT @breadcentric: On my CV: Hobbies: Training bananas to race on tracks #AWSDeepRacer #DeepRacer https://t.co/MKe14hNyux
Wednesday
RT @breadcentric: See how the April AWS DeepRacer races have ended and a couple bits of news: https://blog.deepracing.io/2021/05/09/aws-deepracer-league-2021-update-11-end-of-april-special/ #AWSDeepRacer #Machin…
Monday
RT @sunilmallya: Representation Learning +Instance Transfer to learn new reward functions along with advantage based filtering of new exper…
May 9
Apr 27
Apr 27
RT @f1tenth: Sliding (autonomously) into the weekend like ... 🤖😎 #f1tenth #robots #AutonomousVehicles @OpenRoboticsOrg @NVIDIAEmbedded @Aut…
Apr 25
RT @chr1sa: One of the problems with autonomous car racing is that watching software drive is not a very exciting spectator sport. To help…
Apr 25
