Apologies if this has been asked before.
I am trying to setup a new pixhawk via Mission Planner 1.2.97 . I have a FrSky Taranis radio  with the  8XR receiver and followed an online video to setup the flight modes.
The radio signal is recognised and calibration works fine with the 3 position SG switch on channel 5 and the SF 2 position switch on channel 7.  When I then go to flight modes nothing happens when I move either of these switches.
I noticed on the video that the output above the modes appears to look at channel 5 ( as expected), on my readout it appears to be looking at channel 8 ( so there is no surprise that nothing happens!).
Did I miss something?  Have the default channels changed for pixhawk?
I am completely new to this and the quick start guide is pretty useless.
Thanks in anticipation of your help.
Darrel
  • Hi there, I am having the same issue, i am trying to set up the flight modes but i can not get it to work.
    I have a calmato trainer (fixed wing aircraft) with pixhawk. I went through radio calibration but i do not know how to set up auto-manual switch on my transmitter.
    I am using a spectrum 2.4 receiver bound to JR DSX 11 transmitter. During radio calibration; i have movements on roll, pitch, yaw, throttle, radio 5 ( moves in two positions 1046 and 1849),  radio 6 (moves in 3 positions i highly suspect it is flaps; i have connected ailerons seperate with one connected to main port 1 and other to port 6)
    No movement on radio 8 (but full green bar is there) and on radio 7 (half green and no movement)
    any help on this please.
    rony
  • Ahah - that would do it. I am setting up a plane. Many thanks, I will give that a go tomorrow (it is nearly midnight here and I am not at my best when I am tired!)
    Where was I supposed to see that information? Surely this should be in the quick start guide. The video I found via this site does not indicate whether they are setting up a plane or copter.
    Does this also effect the channel for the RTL switch?
      Are you following the instructions here?
      • Thanks Chris, the information at that location needs a little work, especially now we have the pixhawk (I do realise these things take time, so that is not intended as a criticism). I don't have a copter, so I do not understand why these would need to be different and it did not occur to me that they would be!
        Anyhow I have everything working now with the flight modes switching on ch8 (mixed in with a ch7 switch) and have added appropriate vocal notifications. I will play with this until it becomes second nature to get what I want.
        Next I guess will be the tuning for my Finwing Penguin (my interest lies with stereo aerial photography for mapping purposes).
        Despite these teething problems, I am enjoying the experience.
      • How do I arm the pixhawk for with arduplane firmware ?
        I am using Pixhawk for Skyhunter 1800 mm plane. I have installed latest Arduplane 2.78b firmware. I am using Spectrum DX7s transmitter and connected to Pixhawk via DSMx. I could see all stick movements when I caliberated my Radio, but I couldn't figure out how to arm it and get the motor and servo working.
          Have you installed and pressed the Safety Button (so that it's solid red)?
          • Yes, I did. I pressed the safety switch and then I tried to arm by moving Throttle stick to bottom right but the red light on safety switch didn't go solid.
             This also depends on the firmaware as well, right ? because when I used Arduplane firmware on APM 2.5, there wasn't any need to ARM. The Arming/Disarming was required only in Arducopter, I belive.
    Are you doing a plane or copter? Mode switching is typically CH 5 on a copter and CH 8 on plane
DIY Robocars via Twitter
RT @breadcentric: The handy bit about racing with self-driving cars is that one can type while the car is racing. Report from #AWSDeepRacer…
16 hours ago
RT @chr1sa: Our Bay Area @DIYRobocars meetup is now at 2,700 members. Next in-person events (in Oakland) are training day on July 17 and…
16 hours ago
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Jun 10
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
