Pixhawk Power module problem
I have the Pixhawk AP with power module. The problem is that the Power Module shows a extrange behavior, every time I connect it, shows in the Misiion Planner and the OSD (Minim OSD) the correct voltage (12,5 to 12,6 V on a 3S LiPo batt), but once you begin to use the battery, the voltage showed a sudden drop that provokes all alerts to engage, and finnally PIxhawk enters in fail safe, even though the watt metter clearly shows a healthy battery with more than 11,5 V sustained under load. I already made all the power module calibrations that offer APM and Mission Planner, but nothing appear to fix, what can I do?
  • Did you find a solution to this problem?  I am experiencing a similar issue
    • Did you ever find a resolution?
    • Here is what the voltage looks like 3702554358?profile=original
      • Do you have the 3DR model or a clone?
        • Both.
          The 3DR module was working correctly in February as shown here:
          https://www.youtube.com/watch?v=VQFNICnsTk0
          Early this month the pixhawk started giving readings of 14V (alarming because we are using a 3S battery).  I used the power module "other" option to re-calibrate at the measured voltage but was seeing similar results when capturing the log as above.
          After similar results I bought a power module from wasooo to see if the results would differ but they did not and this module did not produce a log of the current.
          The Vcc is fine to the pixhawk under the load as referenced in the wiki:
          http://copter.ardupilot.com/wiki/common-diagnosing-problems-using-l...
          However, there is no common diagnosis for the "Battery Issues" log and I would like to know if this is typical.
          Thanks,
          Louis
sam liked Jimmy Oliver's profile
Aug 25
Mike Whitney liked Mike Whitney's profile
Jul 19
Abdulatif Tlaib liked Ryan's profile
Jun 24
