Pixhawk Pre-arm check fails "Compass not healthy"
AC3.2 on a 3DR 2014 DIY Quad with Pixhwak.
I have occasionally seen these and usually unplugging and plugging in the battery fixes things. However, today it would not clear and I could not get off the ground. I had done a short test flight earlier without issues in a different location. The compass direction in the telemetry seemed steady, but was indicating a different direction each time I rebooted.
I have recently change the configuration from Spektrum satellite to OrangeRX R800X and added a Fatshark 25mW 5.8GHZ transmitter. Are either of these likely to interfere with the compass? Or is it hardware failure?
Thanks for any info.
andy
  • I'm having the same problem. Even moving the vehicle too much around confuses the compass easily. A reboot clears it away. Is there a way to reboot compass when pixhawk is on?
  • Just to update anyone who googles across this. My findings are:
    - Compass not healthy does not mean hardware failure, it just means the sensor is overloaded.
    - Calibrating outdoors away from all possible sources of interference makes a huge difference.
  • This reply was deleted.
    • Thanks for the suggestion. Obviously the number of satellites picked up by the GPS will have no bearing on the compass performance. I don't want to disarm the check as a bad compass has potentially disastrous consequences.
  • An update on this. I recalibrated the compass very carefully without issue (selected Pixhawk in APMPlanner2). Calibration found two compasses - internal and external I assume - and the IDs were as documented in https://github.com/diydrones/ardupilot/issues/1355 - i.e. both had ID's, compass 2 was NOT -1. Is this correct? The compass heading in APM is correct and responds quickly to movement. Applied power and same result "Compass not healthy". Tried again and got "Compasses inconsistent".
    So here's a weird thing. I apply power with the copter not moving (obviously). If I then rotate the copter a little so that the heading viewed in APMPlanner2 moves the error goes away! This sounds more like a software than hardware issue to me, but knowing zero about the firmware I of course could be completely wrong. If a compass is faulty, how can I tell which one. How can I tell whether the calibration is reasonable?
    Thanks for any info/ideas
    andy
  • I'm using the 3DR uBlox compass/GPS kit as well.
