PixRacer with Ardupilot
This is a discussion to focus the feedback and support of ardupilot on the PixRacer board from AUAV.co.
We believe that all teething problems encountered are now resolved and so we recommend people load Copter-3.3.4 which is available for all multicopters through the Mission Planner's (and other GCS's) Install Firmware screens.  Note that because regular Pixhawks are still on Copter-3.3.3 the install icon may show Copter-3.3.3 but rest assured, Copter-3.3.4 will be installed (you can check the version by looking at the very top of the Mission Planner).
3691274249?profile=original
        with some help from James I've now setup my 250 quad with latest BLHeli firmware (on afro 20A ESCs) which supports OneShot125. I have got it working but it is intermittent. I'm analysing what the cause of the issues is and will post once I have it working reliably.
  • Okay, it happened again, but 100x's worse.
    Just hovering, the quad did a Massive Roll to the left and it plowed into the ground bringing the grass up with it.
    CF frame so no damage.
    In the logs you can see something crazy happened, red lines shoots all over the place, although it was just maintaining a hover over one small area.
    I also see a EKF_CHECK 2, but EKF_ENABLE = 0
    3702226886?profile=original
    2016-04-15 14-14-03.log
    https://storage.ning.com/topology/rest/1.0/file/get/3702226778?profile=original
    • T3
      Edgar,
      there seems to be an error in the altitude estimate. It seems unrelated to the GPS. However, HDOP is relatively high in the beginning of the flight. Hence, there might be some relation. Some NKF data also seem to go wild shortly before the strange altitude estimate.
      It's a little strange. Would be good if a dev can have a look.
      • NKF, do you mean EKF?
        This was stabilized mode so GPS/HDOP should not affect this correct?
        There is surely something going on here but i don't know what exactly.
        • 1. The EKF status window is reporting partly heavy movements (Mainly Velocity up to red , Pos Hor/Vert,Compass a little) while the copter is setting on the balcony desk (@ low HDOP <1) .
          2. The MAG calibration is working for all compass, (turning balls, saving offsets) but is constantly reporting Error 99 for MAG 3 during the calibration process.
          • yeah, I think something here is causing my random pitches/rolls
    • Here is a pic of AHR2 Roll vs ATT Roll
      I'm not sure what one is vehicle or what one is stick
      Documentation says
      RollIn The pilot’s desired roll angle in centi-degrees (roll left is negative, right is positive)
      Roll The vehicle’s actual roll in centi-degrees (roll left is negative, right is positive)
      But I don't see RollIn
      I am not sure why this would happen :(
      3702628394?profile=original
      https://storage.ning.com/topology/rest/1.0/file/get/3702628394?profile=original
  • Is the voltage/current sensor working on PixRacer? I have ACSP4 and cannot make it to show any reasonable values.
    • Yes. Works well for me with these settings :
      3702628907?profile=originalKeep in mind: Voltage calibration w/o load and current calibration should be done with a hi amp load (e.g. couple of Halo bulbs) Don´t expect proper current readings without load. This is not meant to measure quiescent currents ;-)
      • Thank. I will try to test it with the latest build. With my 3DR PixHawk I am able to measure voltage without even arming the motors, it may not be very accurate, but close. With PixRacer I was getting way low values and it triggers falisafe, so I disabled the sensor.
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
yesterday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Thursday
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
