Power problem?
I realy need your help! First of all, excuse my bad english.
I set up a plane with ardupilot mega and the imu sheeld. i attached following
  • ublox gps
  • airspeed sensor
  • 4 servos (aileron with y-cable)
  • xbee xbeexsc
  • esc to power whole system by my 3s lipo
my problem is, that if i test the autopilot with one servo and NO xbee attached, everything works fine.
when i attach more servos, the ardupilot will not boot (flashing leds stopp after some seconds, then it starts over again and again)
same problem with xbee connected.
I tried to work with external power from a 2s lipo (yes i removed the jumper:)
now without xbee everything works fine. my plane is flying on my table now since 20 minutes.
as soon as i connect the xbee, i have the same problem again.
so i tried to give the xbee its 5V from a +Pin from the servo connectors (the esc power source): ardupilot starts, runns perfectly for 1-3 minutes, then restarts again (or hang up)
any idea what i can do? i realy would like to have the telemetry, too
Thanks so much
tom
    It sounds like you've got an older APM board with the buggy PPM firmware (one of the fuses is set for a 4.7v brownout protection, which is too close to the nominal 5v. It should be set for 1.7v. You need to update the PPM firmware, as explained here.
  • Hi Matin!
    With no servos and power from esc it seems working.
    1 servos no xbee over esc is ok. 2 servos sometime.
    4 servos - no way
    all are tiny servos (no hi current)
    edit: gps and airspeed were connectet all the time - no problem with that. MUX led is blinking, too
