PPM Encoder
Might be a silly question
I just wanted to know what the differance was between the PPM output, and the Mux output on the diydrones ppm encoder?
  • is that not the way, but I wanted to see and I can not find solution: in the apm 1.4 load new V2.3.0 ArduPPM ATMega328p.hex ppm encoder. all loads fine but the blue LED blinks fast, and no radio signal. working correctly before loading the new ppm. ppm loading the old solid blue LED and no radio signal. some solution
    Thank you.
  • good question
