PPM signal timings
Hi, I'm trying to feed PX4 with a PPM signal created in software, I can't get it work correctly because I can't find the timings needed.
For example,
1)PPM pulses must be active high or active low?
2)What is minimum and maximum duration of each pulse?
3) Must I provide a fixed number of channels or the board itself counts the available channels on PPM?
Thank you!
  • Hey, did you manage to successfully accomplish this? And do you have any more information on this topic?
  • Hi, I resolved on my own, just for the curious ones:
    1) For PX4 is not important since it watches for the edges, however i used an active low configuration
    2) minimum and maximum duration of a ppm pulse is for PX4 between 200 and 600 us
    3) the board itself counts of many channels are present with a minimum of 5
    • Hi there, I am trying to do the same thing, I wonder if you mentioned ppm pulse between 200 and 600us is the Pulse duration (which is 1200us - 1900us usually) or the interval between 2 edges of Pulses?
      • Hi duc:
        I just intended that in order for the edge to be detected it is enough to set a value between 200 and 600 us. But this value is not the pwm pulse duration.
        The pwm pulse duration in ppm is accounted like this:
        PPM Signal:
        __| 400us |________________________| 400us |__________________|          |__________
            PWM Channel 1 (1000us-1900us typ)     PWM Channel 2 (...)                   PWM Channel n
        • thanks, it works great for me!
