*solved* Problem Flashing Ublox...
Hello,
I bought the rctimer Ublox GPS.
GPS CN06 Features:
         ·Standalone GPS receiver
         ·u-blox NEO-6M GPS module
         ·EEPROM for save configuration permanently
         ·Build in 25X25mm active antenna
         ·UART (TTL) port with EMI protection
·Rechargeable battery for backup/hotstart
Default parameter
         ·Baud rate : 9600
If this GPS receiver used for I2C-GPS NAV Board, it must be changed to baud rate 115200 / update rate 5hz.
I connected this module to my pc and installed the u-center 7.02.
Suddenly there is a question box asking me if I am sure to write the (3DR-Ublox.txt) file on to the gps.
3690983621?profile=original
Should I flash or not?
Kai
  • Go ahead. It is normal... dont worry about this dialog box. Update it with 3dr file. I have done this.. works like a charm.
  • Problem solved.
    I found a solution somewhere in the forum:
    http://diydrones.com/forum/topics/apm-2-5-with-neo-6m-ublox-gps-not...
    Reply by Para on October 19, 2012 at 1:38amDelete
    You can't reprogram firmware in the cheaper NEO units. All you need to do in u-center is Tools / GPS Configuration, select File > GPS, tick the nonvolatile memory option, select 3DR-Ublox.txt and upload to your unit.
    After the GPS restarts in the new config, you'll see in u-center that bar-graphs don't show anything but you'll still see info in one pane about lat/long, number of sats, hdop and pdop.
    Also, browsing config, your serial baud will be 38400, refresh at 250 ms / 4 Hz and output is UBX-only.
  • Admin
    @CyberCrash,
    I believe that the RCtimer NEO-6M is not the same model GPS as the 3DR LEA-6 and you may have a problem attempting to flash it with the 3DR configuration text file.
    Just a thought.
    TCIII
