  • what leds are lit on the oilpan after it initializes
  • Bart,
    I have bias toward using the CLI (refer to wiki on how to go into cli mode) ... once in CLI, choose the menu that calibrate the minimum throttle level of transmitter ... might fix your problem ... by the way one of the menu also in CLI allows you to calibrate your accels ... good luck.
  • did you calibrate your accelerometers?
