Problems Connecting to APM after Update?
Has anyone else had any problems connecting to your APM 2 after the update to the mission planner (1.2)?
On both Mav link (3dr 915mhz) and USB it starts to connect but about 2/3 of the way through it just hangs up and then Times out.
  • Will,
    I notice the same thing.  If I just plug in my 3dr radio and usb for power only, I can connect just fine, however if I plug in my quad motors, and receiver, my radio will not connect (even with a sold green light).
    However!  If I power up the TX, start the arming process, my radios connect every time without fail.  I'm not 100% sure where the problem is occurring, but give that process a try.
  • For anyone having problems, this seems to be the methodology to solving  them: (most of the time)
    First unplug everything from the APM, if that solves it then start adding things back until you find the problem
    IF you still have a problem then do the above but also Put all the settings back to default and then add things until you find the problem
    IF that still does not work, then do all of the above but then ERASE and re-flash APM.
    I know this seems like common sense, But Allot of times you don't even consider things that you "know" could not be the problem. Every time you do that your building on an assumption and when they start to pile up.....well you know that story.
  • I had MP version .87 up and it was showing GPS and was correctly displaying  roll/pitch/yaw in Flight Data screen.
    I upgraded to MP 1.2 Mav 1.0.
    I now have GPS: No GPS on Flight Data Screen.
    What's up with this?
    Thanks to whomever....
  • Well, it is solved!!  I uploaded Adruplane which asked me the EEPROM will be erased, I clicked YES, then I uploaded the Adrucopter again!
    it works fine.
  • Hello,
        I have the same problem with 2.7, I use win7 64 through USB connected to APM2. it starts reading data for a few seconds then it hangs up.
    I am downgrading to the previous version.
  • @Georges P.: You can compile  and upload ArduCopter-2.6with  arduino-0022-relaxpatch
    You can compile and upload ArduCopter-2.7 with arduino-1.0.1-windows using this patch http://diydrones.com/xn/detail/705844:Comment:931817
  • I have also problems on APM2, Mission Planner 1.2 and V2.7.
    My PC beeps when firmware is writing to board and don't know why.
    When I arm the motors and increase speed, 2 of them stop atfer some seconds, and problems with ESC calibration.
    It was correct with older versions and V2.6.
    I tried to reload V2.6 on APM2 with Arduino.exe (Arducopter.pde) but it is not easy (why isn't it possible to choose the firmware version in MP?).
    It seems 2560-2 board is not in the list.
    How can I load V2.6 firmware?
    Help!
  • I have found the cause of my problem. Here is explanation:
    1) AP_Baro::calibrate()
    Suggest to to rewrite this piece of code to avoid hanging in future
    Here is infinite loop:
    while (ground_pressure == 0 || !healthy)
        read(); // Get initial data from absolute pressure sensor
        ground_pressure = get_pressure();
        ground_temperature = get_temperature();
        callback(20);
    The problem issued by erroneous I2C reading. Looks like my compass HMC5883L hanging the I2C line or so...
    2) AP_Compass_HMC5843::init()
    int numAttempts = 0, good_count = 0;
    bool success = false;
    byte calibration_gain = 0x20;
    uint16_t expected_x = 715;
    uint16_t expected_yz = 715;
    float gain_multiple = 1.0;
    delay(10);
    I2c.begin();
    I2c.timeOut(20);
    Added I2c.begin() and I2c.timeOut(20) before the first read of I2C interface as it done in AP_Compass_test.pde .
    This solution works for me. I use compas based on HMC5883L from SeeedStudio.com
    http://www.seeedstudio.com/depot/grove-3axis-compass-p-759.html?cPa...
    Michael.
  • Hello everybody.
    I'm experiencing troubles with ArduCopter_2.7. Connecting via USB to MissionPlanner_1.2. Connection successfull, but  can't get flight data from my APM1. CLI->test->ins shows gyro and acc data being changed while I was rotating my APM1.
    ArduCopter_2.6 works fine with MP_1.2.
    I have attached the MissionPlanner console log and the screenshot of flight data window.
    Michael.
    MP_1.2_log.txt
    https://storage.ning.com/topology/rest/1.0/file/get/3692475123?profile=original
  • 2.7,  I have a laptop and my main computer here, and on both of them halfway through the usb was disconnecting / reconnecting as soon as I started to connect. Using my telemetry radio it would just hang up. I went back to mission planner 1.199 1.0 on my desktop and now I can connect again, but not from my laptop that still has 1.2 on it. weird because it worked for awhile.
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Monday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Thursday
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
