Project Venom Drone Racing Frames
VENOM FPV Racing Drone Frame
Sky Racer Fpv http://skyracerfpv.com/#
New Frame Designs are the future of the drone racing sport although there has been vast improvements in components the H carbon-fiber frame has basically remained the same the future is 3D printing with new technology in printers and materials has made it possible to design lightweight and durable frames with purposeful features such as enclosed battery bay better mounting of components better weight distribution and lower cost easy to replace parts and upgrade Project Venom is set to take the most common problems that faced 3D printed drone frames Impact resistance and weight with cutting edge design and new industrial-strength materials these barriers have overcome
The New Venom Drone racing frame engineered to be tough & lightweight using advance 3d printing techniques and industrial grade materials The Sky Racer Venom Series DIY Kit is set to modernize the FPV drone market with upgraded features a functional design
Features
Achieve perfect center of balance with battery mounted in center of fuselage no top or bottom mounting were batteries can become damaged and fall off with straps that break we moved the flight controller mounting standard 30x30 board to the front of the craft allowing for a center mounting battery cage to protect the fuel system one of the most expensive parts of your machine.
DJI HD Fpv system Ready mounting cut out on top of frame makes it easy to add the new digital FPV system or any analog video transmitter
Easy mount RC receiver and perennials at the rear of the frame provide plenty of room for extra gear light controllers and voltage regulators
Can fit up to 4s - 8s lipo "example two 4s zippy 30a 4000mah in series for 8s or parallel for 4s 8000mah can fit snug inside the fuselage.
Universal arm choices can use 25mm carbon tube cut to custom length can use tbs discovery arm, DJI flame wheel arm or f450 arms giving the builder the most customizable options available
Cost less than expensive than full carbon fiber frames stronger more impact resistant, easy to repair two-piece design individual part can be purchased separately change color just by changing top body
Rear 12mm Round LED Mounting in frame
For more information or to become a test pilot visit http://skyracerfpv.com/#  support@skyracerfpv.com
5334418860?profile=original5334418491?profile=original5334418687?profile=original5334418892?profile=original5334419266?profile=original
