quad copter build questions
I am looking into building a quad copter and I have put together a list of parts. I believe everything here would work but I would like to ask some people more experienced than me about it. I will be adding a gimble and a gopro or similar camera on it as well but I have not chosen those. For the needs I have, would this flight controller be good, is there a better flight controller I could use? If you could point out any other issues or suggestions that would be great I am trying to learn as much as I can before I build. Also if you guys have an suggestions on how to make cut some price off it that would be great, I am open to upgrading it in the future so I don't need top of the line things right off the bat.
Any help is appreciated, Thanks.
Frame
http://www.hobbyking.com/hobbyking/store/__77174__HMF_U580_Pro_Carbon_Fiber_Folding_Quadcopter_Kit.html
Motors
ESC
Battery
Props
  • Hello, I can offer you to read this post about building a copter, there is a flight controller section with a few suggestions. Good luck!
    http://www.rcfair.com/en/blogs/view_entry/12946/
    Build your first quadcopter
    Hello!I advise you that you let a quadcopter be your first RC hovercraft. Proper setup of its electronic components guarantees its stable work, while…
