  • I have a question... On the bottom of the Quanum Nova, there are the electrical connectors. The last of the set has 3 pins, G,out,in.
    I cant find any info on this set. I am guessing a serial port.... Any ideas?
  • I am sure you are right. There are lots of little mysteries here. I have worked my way through several but here's one that has me beaten. Everything (except one function) works as I would want it to. When I key RTL it returns to the spot and descends but does not touch down. It often gets down to 100 mm within a metre of launch, but it will not settle. By contrast, when flying a mission it makes a perfect touch down as programmed.
    There must be a parameter out of whack somewhere, What do you think ? Birdmanpete.
