Question about GPS_HDOP
I sometimes get high GPS_HDOP values (i.e. above 2) so naturally my copter (3DR X8+) fails the pre-arm check. However, once the copter goes up a few meters,  I imagine the signal will get better in most instances. So I was wondering if it’s possible to take the HDOP off the pre-arm check and making it a failsafe, so once the copter reaches its flying altitude it checks the hdop and if it’s too low it does an RTL. So in effect making the hdop kinda like a geofence. Or maybe program the copter to have one HDOP value when it’s on the ground (e.g. 350) and another when it reaches it’s first waypoint up in the air (e.g. 200).
  • This reply was deleted.
    • Thanks, I hadn't considered the scaling of position errors. In my (somewhat limited) experience adding GLONASS doesn't help all that much. Having more satellites doesn't help much if you are in a narrow valley or if you are surrounding by lots of trees.
        Waiting longer to take off does give the GPS 15 minutes to catch up with the almanac.
