Question on my ArduCopter setup Combination
My ready to fly weight is 1220 grams including battery.  Well it didn't even get light on the skids at full throttle.  Here is my setup:
2217-9 BL motors from AeroQuad
10x4.7 APC slow flyer props
Turnigy 25 amp ESCs
Frame 3/4'' aluminum
2200mah 3s 30C Flight Max  Lipo
The tractor props are on the front and rear motors(spinning CW), Pusher props on left and right motors(CCW).  Lettering on props is toward the sky.
Any suggestions?  I ordered some 12x3.8 props.
JC
  • well im hoping you tell us if it did fly correctly at the end...
    any updates
    cheers A.M
    Do you have an access to IR led's and IR receivers? and having an extra arduino board lying around? That way you could easily build small RPM measurement unit to look how those props are actually spinning.
    Have you ever been flying that quad earlier with AeroQuad or any other software?
    Yes tryo to calibrate your ESC's again. That weight should not be a problem. Most of quads are around 800g - 1.3kg. What is Kv amount on your motors??
    Especially if you have used it before with AeroQuad software, you need to calibrate ESC's. We have been having some problems when jumping AQ calibration to AC. This is due AQ used min throttle of 1100 to start engines and AC uses 1040. There are few other issues also with this.
    And it is still work on progress tho r55 in repository is working ok but still be carefull always with repository code due there might be big bugs lurking around. We are updating it almost daily.
    Onlly tested and accepted software gets to ZIP files.
  • Nothing getting hot. I'll try calibrating the ESCs again. Do you think the weight is ok?
    Are your ESCs setup to recognize full throttle endpoints? (ESC calibration done?) Anything getting hot?
Monday
Azjeg liked Azjeg's profile
Apr 27
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
