Radio Setup Not working?
Hi, Im new here. This is my first setup of the arducopter and I cant get the radio setup in the CLI to work! Normally after you type radio into the CLI it should say... "Put your sticks to the extreme (or something along those lines) " But it does not!It outputs a blank line and nothing else. and doesnt respond to other commands.Any Ideas? Should I downgrade the Firmware? Im using the latest one.
  • I managed to downgrade my board and got it to show the message that I wanted, HOWEVER, it does register any signal from my RX. I have tested this with motors and it works fine. Any ideas now? Also Interestingly the esc and motors respond when i move the sticks. But in the CLI there is no registered signal.
    I did have this problem after upgrading to latest beta, i solved it rebooting a couple times. Eventually i think you could try to erase the eeprom if reboots do not work.
