Red Solid Led
Hi pixhawkers,
Yestarday, I tunned up my Skywalker 1900 (check cg, charge battery and changed the 3dr radio). Today when I was about to go to the field, I connected the battery and the led was solid red. In adition, there was no way to connect using the 3dr radio, or directly plugin the usb to the pixhawk
I did the following troubleshooting :
          - remove the sd and clean it (none improvement)
          - flash the Rover firmware and flash again the Ardu plane firmware. (it flashes well but once the flash is completed, Red led again.
         - i found the bootlog that it says: No ms5611 found
         -Then i connected trough nsh, and when i type ms5611 start:
    [MS5611_SPI] on SPI bus 4 at 2 (1100Khz)
    ms5611: no device on bus 4
       [MS5611_SPI] on SPI bus 1 at 3 (1100Khz)
    ms5611: no device on bus 3
    ms5611: no device on bus 1
    ms5611: no device on bus 2
    ms5611: driver start failed.
Does anyone has any idea about whats going on and how to solve it?
Thanks,
Jordi
