Replacement 3DR Motor Bearings
One of my 3DR Motors (AC2830-358) does not have the same "feel" when rotating as the other motors. I suspect that one of the bearings is failing. Instead of replacing the whole motor, I hoped that I could purchase a replacement bearing to fix this without buying a whole new motor.
While it appears the inner diameter is likely .125" (3.17mm shaft diameter = ~.125"), the outer diameter is unclear to me, and I don't have calipers to measure.
Has anyone tried to replace these bearings before? If so, what did you use to replace them with?
Thank you for your help! I'm loving my 3DR Quadcopter, and I want to make sure I can continue flying!
  • Did you ever find replacement bearings for 3dr motors?
    • bearings for 3dr motors are:
      2830 : 1/8"X5/16"x3/32" These are the same bearings as the blade 350QX.  A complete set of 8 bearing is available from Fast Eddy bearings for $8.
      2836 : 4x10x4 MR104-ZZ also available from Fast Eddy for a buck a piece.
      Tiger Motors suggest changing bearings after 60 hours.  I suspect the 3DR motor's stock bearings are not the Japanese ones found in tiger motors, so maybe we should change out a little more often?
DIY Robocars via Twitter
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
yesterday
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
RT @a1k0n: This was epic. My car was barely working this morning, had to make a lot of changes and extremely dirty hacks. Post-race analysi…
May 22
DIY Robocars @ Circuit Launch, 3/7/2020 https://twitch.tv/diyrobocars
May 22
