Robot Navigator--SCU SLAM
    BW-SLAM system is a robot self-localization navigation system developed by Benewake. The SLAM algorithm fuses multiple sensors such as LiDAR, visual unit, inertial measurement unit, and odometer.
1. Product Overview
1.1Product Picture
3691361789?profile=original
1.2 Function Frame Diagram
3691361931?profile=original
    SCU is based on Rockchips RK3288 core4, Cortex-A17 1.8GHz processor, Mali-T760 MP4 GPU, 2GB DDR3 ROM, 16GB eMMC, WI-FI and so on, equipped Ubuntu14.04 origin system, using powerful, stable hardware platform to run SLAM.
SCU navigator can be used more than:
  • Robot Navigation
  • Robot Route Planning
  • SLAM Mapping
  • Obstacle Avoidance
2. SCU Introduction and How to connect
3691361973?profile=original
3691361951?profile=original
Number
Typ
Conditions
Quantity
1~4
UART
0~5.5V
4
5
PWM
0-3.3V
1
6
CAN
0~5.5V
1
7
Power
8~25V
1
8
I2C
0~3.3V
1
9
FAN
5V
1
10
Ethernet1
1
11
Ethernet2
1
12、13
USB2.0
4
14
Reset
1
15
OTG
1
16
TF 卡
1
17
HDMI
1
18
WI-FI module
1
4. Connector
TYPE
CONNECTOR
CONNECTOR TYPE
BRAND
HDMI
HDMI
47151-1102
Molex
Ethernet
RJ45 Jack
HR911130C
HanRun
CAN
Wire-to-board connectors
PH2.0-3
OTG
Micro USB
UN51513-DB001-7H
Foxconn
UART
PH2.0-3
USB2.0
USB2.0
UB11121-8FDE-4F
Foxconn
Power
43650-0213
Molex
Fan
XH2.54-2
5. Connector Definition
5.1 Power Connector
3691362074?profile=original
PIN1:+12V Input;
PIN2:GND
5.2 UART Connector
3691362012?profile=original
PIN 1: TXD; PIN2: GND; PIN3: RXD
5.3 PWM Connector
3691362084?profile=original
PIN1: PWM Output;
PIN2:GND。
5.4 CAN Connector
3691361987?profile=original
PIN 1: CAN_H; PIN2: CAN_L PIN3: GND
5.5 I2C Connector
PIN 1: SCL PIN2: SDA PIN3: GND
6. Product Dimensions
3691362021?profile=original
Unit mm
7. Attention
  • This version prototype need waterproof
  • Work Temperature: 0-70 ℃, Storage temperature:0-80 ℃
  • Avoid using the product while in acid environment
8. SLAM How to Connect
3691361999?profile=original
NO
Type
Connect to Terminal
1
UART
Control Terminal
4
UART
Moving Chassis
7
POWER
Power
12~13
USB 2.0
LiDAR, Camera with random order)
9. SLAM System Function
  • Self Mapping
  • Relocation
  • Target Navigation
  • Stop Navigation
  • Obtain Maps
  • Obtain Route Planning
  • Check reaching destination
  • Maps Storage and Deletion
  • Navigator & Explore Mode
  • Speed Control
