RTL mode malfunction in APM plane result in crash
hi, i dont know what happened all of a sudden my RTL mode is not functioning correctly and plunges straight down from 250meters. It happens when i manually trigger the RTL because my battery was running low. The RTL was functioning correctly before i update my mission planner. I kept on updating my firmware and mission planner to the latest version and the error still happens. Has anyone ever encounter this problem?
  • thanks so much andrew and andreas,
    i see, maybe i missed interpreted the incident. it may be the the battery voltage. but i tried to test the RTL on the ground by carrying the plane away from the home position while giving it a little throttle so when the RTL kicks in i would know if the plane tries to go to home position, but when i change to RTL mode the motor stops. im afraid if this could happen in mid flight again. Can you check my parameter settings.
    go discover (21-09-2015).param
    https://storage.ning.com/topology/rest/1.0/file/get/3702097217?profile=original
      Hi Ariff,
      That is caused by throttle suppression, which is a safety feature to prevent the motor starting and hurting someone if you temporarily lose RC control while on the ground and the failsafe kicks in.
      It will start the motor if you are moving at a significant speed or are more than a few meters off home altitude.
      Cheers, Tridge
    I think Andreas is right. The 4S battery is completely dead at the end. The plane was trying to climb to keep at the desired altitude and ended up stalling when the airspeed dropped to 7m/s.
    The FS_BATTERY_VOLTAGE was set to 12, which is far too low assuming you are using ordinary LiPo batteries. If your batteries are special low voltage batteries then let us know (there are some LiPo types that can keep going at that voltage, but they are quite unusual).
  • Ariff, Your planes stalled because there was no more power to fly. Your battery was below the 3V per cell mark. At this point the battery can not deliver any power.
  • incident occurs at tlog=98%. Is there any method to test the rtl function on the ground without being airborne, i dont want to crash them again
    2015-03-12 16-38-19.tlog
    https://storage.ning.com/topology/rest/1.0/file/get/3702096888?profile=original
    Hi Ariff, have you posted a log somewhere?
DIY Robocars via Twitter
RT @a1k0n: @SmallpixelCar @diyrobocars It's just something that's easy to track with chroma keying. I ended up using different colors on th…
yesterday
yesterday
RT @TinkerGen_: "The Tinkergen MARK ($199) is my new favorite starter robocar. It’s got everything — computer vision, deep learning, sensor…
Nov 23
Nov 23
RT @roboton_io: Join our FREE Sumo Competition 🤖🏆 👉 https://roboton.io/ranking/vsc2020 #sumo #robot #edtech #competition #games4ed https://t.co/WOx…
Nov 16
DIY Drones via Twitter
First impressions of Tinkergen MARK robocar https://ift.tt/36IeZHc
Nov 16
Our review of the @TinkerGen_ MARK robocar, which is the best on the market right now https://diyrobocars.com/2020/11/15/first-impressions-of-tinkergen-mark-robocar/ https://t.co/ENIlU5SfZ2
Nov 15
RT @Ingmar_Stapel: I have now explained the OpenBot project in great detail on my blog with 12 articles step by step. I hope you enjoy read…
Nov 15
RT @DAVGtech: This is a must attend. Click the link, follow link to read the story, sign up. #chaos2020 #digitalconnection #digitalworld ht…
Nov 15
RT @a1k0n: Got a new chassis for outdoor races (hobbyking Quantum Vandal) but I totally didn't expect that it might cause problems for my g…
Nov 11
First impressions of the Intel OpenBot https://ift.tt/36qkVV4
Nov 10
Nov 9
Excellent use of cardboard instead of 3D printing! https://twitter.com/Ingmar_Stapel/status/1324960595318333441
Nov 7
RT @chr1sa: We've got a record 50 teams competing in this month's @DIYRobocars @donkey_car virtual AI car race. Starting today at 10:00am…
Nov 7
Nov 6
RT @a1k0n: Car's view, using a fisheye camera. The ceiling light tracking algorithm gave me some ideas to improve ConeSLAM, and having grou…
Nov 5
