Hi there.
Here is my Funpilote based copter, so few thins home made here.
This is not a Arducopter plateform, butI like it. Mostly because this is real pilot stuff. Here are the features:
- 376g without battery nor Gopro
- The protective hull is from a Gaui 500X. It fits perfectly!
- With the 180g battery ~13min flight possible (loopings and not just hold ding position)
- controled buzzer to find it in the field and to scare cows and dogs
- controled LEDs to flight at night
- ACRO mode by default
- STABLE mode but not as good as Arducopter
- STABLE Altitude hold mode with barometer but not as good as Arducopter
- Gopro mount
- Video transmitter mounted on the Hull (not on photos)
Here is a video from the Gopro:
I modified the Camera foam attachement, now I can pu the gopro or an old 6grams CCD camera when recording is not necessary. The foam include now the 5.8Ghz Video transmitter, and the receiver antennas are vertical to improve range. On of the antenna will be bend forward in order to use the receiver diversity system correctly.
