Hi Everyone
I thought as a website called DIY Drones, this might be a good place to post a blog about exactly that. This is my DIY drone (or UAV as I prefer to call them). I had already built a 650mm hexcopter with brushless go pro gimbal and so after doing that I decided to build something a bit bigger so my next project is going to be a heavy lift Octocopter and 3 axis gimbal for a DSLR size camera.
I have completed the gimbal today and below is a video of the results. I have to say its the most technically challenging build I have ever done and I've also learnt that carbon fiber is not the nicest material to cut and sand! but have a look and see what you think. If you would like more information have a look here http://www.copter-cam.co.uk/multirotor-build-blog.php
You rock, your taste in music ... eclectic. ;-)
After doing alot of number crunching with prop, motor, and weight combinations, it seems after you add the extra weight and current draw of 2 motors and arms into the calculation, 6 motors are more efficient than 8 at least with the motor, prop combo I have chosen. The next decision to make was whether to go with 22mm carbon fiber tube or 19mm box section aluminium arms.![3692866642?profile=original](https://storage.ning.com/topology/rest/1.0/file/get/3692866642?profile=original)
![3692866532?profile=original](https://storage.ning.com/topology/rest/1.0/file/get/3692866532?profile=original)
Now you would think it would be a no brainer with the CF tube weighing 40g and the drilled out aluminium 75g, but after you consider the CF arm needs 4 clips, 8 nuts and bolts and a CF motor mount and the aluminium only needs a ply motor mount and 3 nuts and bolts, there's only a 6g advantage to CF. If you then add in cost and possible radio interference issues of CF, then I think aluminium is the way to go
