scratch build 3 axis gimbal and octocopter
Hi Everyone
I thought as a website called DIY Drones, this might be a good place to post a blog about exactly that. This is my DIY drone (or UAV as I prefer to call them). I had already built a 650mm hexcopter with brushless go pro gimbal and so after doing that I decided to build something a bit bigger so my next project is going to be a heavy lift Octocopter and 3 axis gimbal for a DSLR size camera.
I have completed the gimbal today and below is a video of the results. I have to say its the most technically challenging build I have ever done and I've also learnt that carbon fiber is not the nicest material to cut and sand! but have a look and see what you think. If you would like more information have a look here http://www.copter-cam.co.uk/multirotor-build-blog.php
  • You rock, your taste in music ... eclectic. ;-)
  • After doing alot of number crunching with prop, motor, and weight combinations, it seems after you add the extra weight and current draw of 2 motors and arms into the calculation, 6 motors are more efficient than 8 at least with the motor, prop combo I have chosen. The next decision to make was whether to go with 22mm carbon fiber tube or 19mm box section aluminium arms.
    Now you would think it would be a no brainer with the CF tube weighing 40g and the drilled out aluminium 75g, but after you consider the CF arm needs 4 clips, 8 nuts and bolts and a CF motor mount and the aluminium only needs a ply motor mount and 3 nuts and bolts, there's only a 6g advantage to CF. If you then add in cost and possible radio interference issues of CF, then I think aluminium is the way to go3692866642?profile=original3692866532?profile=original
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
