Signal loss while auto mission
I'm flying often using auto mission.
I'm currently on arducopter 3.2 RC10.
Yesterday, while a mission, I reached the limit of my frsky signal.
I wonder what will happen if I loose my signal while the mission ?
I configured a failsafe directly on my frsky to call RTL mode when losing the signal.
When I test this situation on the ground :
- Armed my quad
- Switch to AUTO
- Turn off my radio
Mission planner show me RTL
Will it be the behavior on the air ?
If yes, there is a possibility to do not call a failsafe while in "auto" flight mode ?
Thanks in advance
  • If you use the Throttle Failsafe designed into the firmware you will have a choice whether to continue the mission, RTL, or LAND. Have you read the wiki on setting failsafe?
    • Yes, but a "long time ago"...
      I don't remember why, but when I configured my FS i choosed the way by using the FS of the rx/tx rather than the firmware way.
      I will read again about that.
