simple UAV community security
Hi Forum members- seeking help on this subject.
Seeking a multi-copter UAV for surveillance in a gated community.  As our guards need to operate it has to be very simple to operate. features
GPS pre defined route (autonomously) pre-programmed
Return to home (low bat, etc) and land / power down
Live stream Camera / camera mount (thermal preferred, night vision up to 30 meters)
Very simple start / stop operation (Will not be flown manually once routes pre- programmed)
The distance is quite large  1.35 km from take off point, although the drone would follow roads so flight time is relatively short.
  • Have you tried getting in touch with any UAV Companies to see if they can help? I would recommend SUAS Global info@suas-global.com hope this helps.
