C-astral wings (website) are identical to the wing X8 Skywalker (or the opposite!), but the perfomance are very different. What could double performance of the c-astral? The outer covering (composite or carbon)? The motor / prop combination? My goal is to create a similar astral-c wing, long flight endurance, tilt&pan camera or a lightweight sony alpha like a5100, parachute for landing and a Pixhawk (their mission planning software looks suspiciously like Mission planner anyway!)
Thanks everyone
Alex
Do you know if anyone tried to rebuild and/or reverse-engineer the C-Astral flying wings?
Hi Graham.
I'm building an X8 that requires at least 90min flight time.
AUW would be around 4.4kg
Battery would be 16000 6C 15
What prop and motor would you recommend.
Using Pixhawk 2.1 cube.
Many help would be muchh appreciated.
Graham Dyer said:
Found this: https://www.youtube.com/watch?v=qzEIqMtkMwM
At these Re numbers really the only thing that is going to matter is your propulsion system efficiency, and whether or not the airframe can support the load structurally. With the same propulsion system, wingspan and structural capacity the two drones would almost certainly perform within 10% of each other range wise.
I got 2h17m and 114km with a Super Skysurfer with an un-aerodynamic gimbal and a weight of 3KG. I suspect that with the same battery/motor combo an X8 would have easily gone further/longer as flying wings are quite a bit more efficient with lower drag than a conventional layout.
How much further/longer - maybe 2h45m/150km, perhaps even 3hrs? It is possible with the X8 and conventional motors/props/ESC's.
One just has to choose carefully and optimize each component.
Hi Alex,
You can source a composite X8 from Skywalker themselves. They released the composite X8 towards the end of last year, if memory serves. I recall that the wiglets pointed down... You can search the site, I'm sure you'll find the discussion.
My point is that getting a commercially proven air frame like the X8 and matching it with the right battery/motor/prop combo for your payload using a tool like ecalc will remove a lot of the painful trial and error.
Good luck with your mission.
Here is the link to the discussion:
http://diydrones.com/profiles/blogs/skywalker-x8-honeycomb-composit...
Hola a todos, estamos desarrollando un concepto de seguridad para el skywalker x8 y otros drones de ala fija, que les dan mayor precisión y rendimiento, además de proteger el equipo en el momento del impacto. Este sistema tiene cardán, baterías de alta duración de 120 minutos y paracaídas. ¿Qué piensas de nuestro trabajo? Saludos
Hi to Avio team and thank you for your reply,
wow, it's very similar to the UAV C-Astral, it is impressive.
Is it possible to put a larger battery for more endurance or the space dedicated to the lipo is specially made for a 3S / 3000mah?
I also see your UAV X, very interesting too.
Could you send us a quote to know the prices and options available for your two machines?
You can send it to admaltaisATgmailDOTcom
thank you
Alex
Hi Kev and thanks for the relpy,
You're right, there are not the same, but pretty similar.
I know the "C4-eye" is really impressive, but it is between $ 50k and $ 100k and I do not need all the accessories.
Knowing that the market is actually at the beginning and that the applications are still nebulous, invest $ 75k would be quite risky.
You say apm is not optimized for long flights, why? Yet C-Astral mission planner looks (very similar;)) like Mission planner / apm planner!
Do you think that building a composite mold for an existing model (X8, FX79) would be a good option (not knowing how much costs a mold!)
Thank you again
I will continue to search the forums.
Alex from Montréal
