Smoke from motors
Hi
I am currently working on a hexacopter. After completing the assembly I tried to calibrate the motors. One of the motors didn't spin properly and smoke started coming from it. This happened twice. I don't know if the problem is with the motor or the ESC. I made sure all the wires are perfectly soldered and connected. Attached sleeves as well. I am really not sure where the problem came from. Would be great if someone could tell me where I went wrong. Btw, Im using T-motor 400kv and T-motor ESC 40A.
  • Can u please tell me the kv of motors and battery which you are using
  • Are those ESC's OPTO or do they have built in BEC?
  • There is no calibration or signal the pixhawk could send that would burn your escs.  Do you have multiple bec power from escs in parallel?
    Amit said:
    i just got 2 motors burned at the same time, Tmotors and castle esc
    Its got to do with calibration or signals, motors number 1 & 2
  • i just got 2 motors burned at the same time, Tmotors and castle esc
  • new...and defective.
    All you need is one bad soldered gate signal on one FET to end up with DC being applied to a motor (that can admage it)
    ..or a incorrect winding or connection of leads from the motor - which also could damage esc ..
    (This is a reason to start things first time on a lab PSU , or have other means of current limiting during test)
  • But the motors and the ESCs are brand new :/
    Andre K. said:
    you can try to use the esc with another motor.
    - the burned motor is to be considered defective. (the insulacion between windings is most likely defective now)
  • you can try to use the esc with another motor.
DIY Robocars via Twitter
RT @a1k0n: @DanielChiaJH @diyrobocars @circuitlaunch Here's my car's view of that race. About 8.4 second lap times for laps 2 and 3... both…
yesterday
RT @DanielChiaJH: Great racing against @a1k0n today at @diyrobocars! Pretty cool to both break sun-9s at the track today I think I got very…
Sunday
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
Saturday
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
Saturday
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Sep 26
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Sep 26
Sep 26
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
Sep 10
Sep 10
Sep 10
