hi everyone,
i´m german. sorry for bad english :(
i have an tbs style frame (eyefly goliath).
weight 1800g
4s lipo
tiger mt2216 900kv with graupner eprops 11"
auav-x2 with arducopter 3.2.1
all together i´m happy with the software.
but i think it could be better. if i giving full pitch i´m getting wobble. i don´t which axis, but i see it on ccd cam.
in the past i tested several autotune. it was always very crispy. especially at pitch axis. but the esc sounds very strange.....the reason was that rate pitch D was more than 0,02 and rate pitch p often more than 0,25, sometimes over 0,3.
so i tuned manually and i think it´s ok. but the wobbel is uncool.
another question....in poshold at 20km/h wind....is it ok, if there is a little bit swinging? could it be better?
attached are my pids and a log from last flight with stabilize and poshold.
3691216160?profile=original
2015-06-15 20-03-54.bin
  • Hi SpeedyHulk,
    this are my current settings with AC 3.2.1:
    3702030326?profile=originalI've attached a log also. Don't know if there is something helpful in it, it was just a short flight a few weeks ago...
    2015-05-18 19-53-32.log
  • Hi, I'm flying nearly the same setup, except for the props (I use Grauper's 9x5 and sometimes 10x5). But my PID values are way bigger: http://diydrones.com/photo/pid-settings-for-tbs-disco (except for Stab P). I tuned them manually a long time ago and the machine flies great in every mode. (The IMAX values have changed since I'm using the default values, which are higher now.)
    All the best, Markus
    • Hi Markus,
      thanks for reply.
      i see your pids are completly difference. why did you Change imax at roll and pitch? what makes it?
      it seems that your "d" is low for such high p-values. if i would raise p it would be overshot, i think.
      do you have a log?
      Greets
      • Hi SpeedyHulk,
        I didn't change IMAX manually. The default values changed from my first Arducupter firmware (2.9.1) till now (3.2.1), and as I use the default values they changed in my setup from firmware to firmware. I didn't notice any difference.
        As I am not at home at the moment I can't check, which IMAX values are default at the moment. I will have a look tomorrow - and also attach a log.
