In the CLI when I enter the altitude test mode I never seem to get a response from the sonar. I get values that look like this:B_alt: 3801088, S_alt: -805257695B_alt: 3801096, S_alt: -805257695B_alt: 3801122, S_alt: -805257695B_alt: 3801122, S_alt: -805257695B_alt: 3801114, S_alt: -805257695or sometimes like this:B_alt: 70, S_alt: -805257695B_alt: 96, S_alt: -805257695B_alt: 122, S_alt: -805257695B_alt: 140, S_alt: -805257695B_alt: 114, S_alt: -805257695Which raises another question: what kind of values am I supposed to be getting for the barometer?I've confirmed that the sonar is enabled, I've also checked it with a voltmeter to see that it's outputting a voltage relative to it's proximity to objects. I'm using a Maxbotix LV-EZ4 sonar.I'm also pretty certain that my barometer was working under Ardupirates, as I was able to use altitude hold fairly high up. Anyway, it seems to respond to changes in the quad's height (me waving it around), I'm just not sure why I get values in the millions sometimes, and values in the hundreds some other times.
This has been fixed as of r2242 with a change to a printf type variable. Either check the changes in the trunk and make the modification manually, or download the latest trunk code to get up to date. ;)
am also getting weird numbers, B_alt oscillates around 100+/-50, sometimes dropping to 0 and sometimes up to 65000, without any movement of the apm, also no props installed, so that cant be the issue...
Also looking at code it seems to default to use the XL sonar rather than LV. I tried changing that to LV like in pirates code , but it generates a compile error.
Al
